starfox86
Took off the lense. This was hard but it turned out pretty well. I looked at LsUnV2's pics for help. I dremmeled the outter lip off the housing like suggested which was needed to be done. It took about an hour. Then, I used a flathead to carefully break the bond with the under part of the lense. and the housing. After another hour I was able to gently pry it apart. It looks better than I thought it would, more pics..
I had to remove the black plastic housing. I will also have to cut the inner back part of the headlight housing for the bi-xenon part to fit.
Just a mock up of where it will be.
I ordered E46 shrouds that kind of have the same design of our highbeam part of the assembly. They should be here Monday or Tuesday.
I'll post more to this when I finish this week.
