Stainless Steel Breaklines?
is it worth the install? do u feel the difference? do u recommend it? i dont autocross so let me know..
braided brake lines are always gonna be worth the trouble. your brake will be smoother and faster it will be alot nicer. you wont really notice it alot until you go to do a hard brake
I was wondering the same thing but figured for a DD I would be happy w/ just putting the EBC red pads on and eventually the slotted/dimpled rotors.
yes you will be happy you will notice a difference. like i said it wont be real notice able unless you have to use your breaks hard but bangin were in florida we use our breaks hard all the time. also just remember the stock lines expand and cause the braking to be slow while braided lines dont expand under pressure meaning a better stop everytime so in my opinion yes it is worth upgrading on a daily driver
yeah its worth it. Even if you do not need a preformance pad and/or dimpled rotors, the lines will make a difference. In fact they may improve the feel and braking enough that you do not need to upgrade the pads or rotors.
I changed the LS hoses when I changed the pads to thermo-quiet units from Wagner. The difference was very noticable, but now I'm not sure if it was the lines or the pads. Either way, the pedal is firm enough and the LS stops quickly and solidly from any speed.
is it worth it?.......
Well - I guess I would be considered a 'sprited' daily driver, a little hard on the gas, a little late/hard on the brake (I try not to use the brake, but when I do it is usually late)
So I felt the 3800lbs car was too slow to respond during braking - that's why I did everything I could:
• CC RotorWorks drilled and slotted rotors
• Porterfield Racing Dustless Carbon Kevlar Pads (R4-S High Performance Street and Autocross)
• StopTech Stainless Steel brake lines
• Dot4 - 446 degree brake fluid
• Brake cooling vents in lower grill (NACA Vents, aluminum brake spindle hose mount, Neoprene Duct Hose)
Where can I buy this lines cheaper on the net. Here in PR their asking me $193 for all 4
i got cross drilled and slotted rotors already.. dont know if i should get the lines.. maybe when i have to get new rotors..
The stainless steel brake lines will help you more than rotors and pads will anyway. The steel brake lines will not flex like regular lines will thus improving a firmer pedal feel. Stainless Steel brake lines provide a number of benefits as compared to their OEM rubber overmolded counterparts.
1. The SS braid provides superior protection from flying roadway debris.
2. The SS braid and Teflon hose reduce expansion during pressurization.
3. They provide the race car look.
There seems to be a misconception regarding brakes. People think cross drilled/slotted rotors will help them stop better. This is not necessarily true. For most performance applications slotted is the preferred choice. Slotting helps wipe away debris from between the pad and rotor as well as increasing the "bite" characteristics of the pad. A drilled rotor provides the same type of benefit, but is more susceptible to cracking under severe usage. Some people prefer the look of a drilled rotor and for street and occasional light duty track use they will work fine. However, since EBC offers a dimpled rotor instead of through holes the integrity of the rotor will hold up better.
Now, the discussion on brake pads. There are numerous different types of brake pads. Some have a higher heat tolerance (less thermal shock) and wear slower (longer pad life). Some have a lower heat tolerance (more thermal shock) and wear faster (lower pad life). It all depends on the amount force and heat generated by the brake system and the operator. It's hard to get a brake pad that wears great and stops great. You normally have to sacrifice one or the other. Brake pads like the OEM pads are suppose be a longer wearing pad but typically fade out after a lot of heat is applied. Performance pads like the Porterfield R4-S and EBC Red pads have a lower heat tolerance but perform better once the pad and rotor gets hot.
You have to determine what you want to accomplish with your brakes. I prefer to have great stopping power but realize the pad life will less (and possibly more brake dust). However, I will stop sooner since I am harder on the brakes. If you are more of a non-brake person and don't typically race or run your LS hard then I'd simply stick with a pad that will save you money over the long haul. In this case, adding the stainless steel brake lines would be beneficial since it would give you a firmer brake feel. I'd recommend the stainless steel lines for everyone. You won't realize how mushy the LS brakes are until you put the stainless steel lines on.
I have a couple of antique show cars and all of my lines, Brake and fuel are stainless. That way I never have to worry about rust in the lines. I am not as concerned with bursting points but they are much harder so they should be better. Anytime I have to replace a line I will use stainless -worth the piece of mind!
