Staggered Jag Wheels
Jacknbeef
Northern Illinoy
Hey all. I have been searching all morning and can't find a definitive answer if 20x9.5 wheels off of an 07 Jag XK will fit the rear of my 06 LS8. I have access to a shop and can make minor mods to the wheel well if the fit is close. Thanks.
Well...
The offset is what matters. The 19 X 9.5 inch S Type R rims fit in the back of all year LSs but the offset is +60. As a rule no one has successfully put a staggered set of OEM Jag 20's without having rubbing issues because the 9.5 width with the +35 offset makes the rims stick out too much.
However many people have ran 4 front 20X8.5 Jag rims lowered with no problems.
Thanks for the quick reply. I think the offset on these is 45, at least thats all I could find on a website that sells OEM wheels. They are the silver 9 spokes.
The other question I have is how bad are the rubbing issues and can they be fixed on a lift with a sledgehammer(joking about the sledgehammer)
There is not much you can do to fix rubbing in the rear. The fender cannot even be fully rolled cause the door is part of it. Take a peak inside the rear wheel arches and you will see
I think the bolt pattern for the jaguar xk is 5x120. The bolt pattern for the LS is 5x108.
I was just looking at the bolt pattern. The seller has the wheels listed as off of an 07 but you are right, the 07s are not 5x108, the 08s are though. Either way I am not going to buy them but thanks for all the help.
