sport shifter abnormalities
Lincoln LS
  1. smegun
    smegun Well-Known LVC Member
    200
    Aug 5, 2018
    deltona, fl
    so if i switch from 3rd to 2nd even at below normal or slow speed i get a long delay then excessive revolutions like it skips 2nd and drops right into 1st .... im thinking about changing the torque converter already cleaning the solonoid pack and valve body i think part of the torque converter may be blockn a solonoid or something is electrically wrong ...havent pulled any codes
    i dont use the sport shifter but i probably would to downshift otherwise race around a bit or take glide momentum off getting into a tight turn
  2. 04_Sport_LS
    04_Sport_LS Dedicated LVC Member
    3,425
    391
    Jun 12, 2012
    Somewhere around Lake Erie
    What year is your LS?
  3. smegun
    200
    Aug 5, 2018
    deltona, fl
    2002 sport 3.9
  4. 04_Sport_LS
    3,425
    391
    Jun 12, 2012
    I'm not as familiar with the first generation... as I am with the 2nd generation... but you mught want to try adjusting your shifter cable underneath the car where it connects with the shifter linkage.
    I really don't think there is an issue with the torque converter.
  5. FDR
    FDR Dedicated LVC Member
    1,993
    139
    Jan 20, 2014
    Central NJ
    I don't think anything after D5 or D4 changes the cable. I know the +/- position on the Sport trim is just 2 switches under the bezel. I don't know how exactly the base 3/2/1 shifter is setup, but I do know it utilizes the same type of switches so that you can swap between types and flash the pcm to make it work correctly. I assume it disengages the cable in the shifter when you move it over the the right or something
Share This Page
