speedometer ?
foolzgold
col
I have a 97 that keeps resetting the mileage counter every 10 miles. It is stuck on a 10 mile loop. when it resets back, all the dash indicators light up as if I just turn the key on, tach and speedometer drop to zero the return to normal until i reach another 10 mile of travel. Is this a dash issue or VSS ? or ? Thanks
Honestly sounds like a bad alt. or battery, I don't see why resetting you trip would cause all the lights to pop on.
i think this is a thing. some 2nd gen speedos have a bug in the programming. i have heard of it before.
Thanks, I have'nt had any charging problems and my mileage counter will not advance pass 10 miles before resetting itself.
the mileage only shows 44302, at 44311 it resets back to 44302
When the mileage goes back does the car repair its self from any damage done in that 10 miles?
Do you drive home in reverse?
Sound like a bad gauge cluster...
Your car is forever young!
Sounds like a programming issue since Gen 2 gauge clusters' Odometers are digital.
The Mark VIII version of Christine.
