My Right Front Door Speaker is a little crackly and I want to replace it. What speakers are compatible? I have the standard Audio with a CD6 that is not branded.
I guess I should have been a little more clear - I am wondering what years of Speakers from another LS or FoMoCo car is Plug-N-Play.
I put Polk components in the front doors (the tweeter is surface-mounted on the panel opposite the outside mirrors) and Infinity Reference speakers in the rear doors. I also added an RF amp..... It was quite a bit of work and wiring, but I am still, 14 years later, satisfied with the results.
Could you post a picture? I've been shopping for components to replace my stock Audiophile door speakers and knee tweeters, especially since I opted to not reconnect the tweeters to the new head unit. I've seen component tweeters mounted to the dash and think they look awful. My only problem with the mirror area is I don't want them to look tacky and out of place either
I wouldn't do 5.25s... you lose out on too much mid bass, if your not going to use 6x8 speakers, use 6.5" speakers with 6x8 adapters.
I have the Audiophile package with what I'm pretty sure are 5.25"s and 1.5"s placed side by side in a 6x8 basket, so I figured nice 5.25 components could only be better. This may not be the exact part, but it's looks very similar. I didn't investigate it much when I had the door panel off
At this point, I think I'm pretty set on a component setup, especially if I could match up my spare Mach tweeter grilles from my Taurus to the LS
Here you go..... Once my phone finishing sending I should have a couple more...
also the OP said that he had the standard/base package
You can get remote tweeters to color match perfectly with SEM upholstery dye.
I noticed many of the 5.25 and 6.5 components' reviews complain about lacking bass. Do you have any input on that?
Is there a significant difference between 6.5s and 6.75s? Depth? There are many more 6.75s than 6.5s available.
Is a component system even worth the effort? I haven't given any thought to the speakers in a long time
most people replace speakers expecting better sound, but better sound to a lot of people is "more bass" honestly if you replace a normal factory speaker with an aftermarket speaker, there will not be much if any more bass, honestly, most of the time there will be a little less bass. this is due to most factory speakers being one way, and most aftermarket speakers being two way (or more) those extra drivers require some power to drive which leaves less power (again, not much) for the bass woofer. also good components tend to be a little more heavy duty than an OEM speaker, and thus are not quite as efficient and therefor sometimes need a little more power to be just as loud. then there is the part where most of the time, the aftermarket speaker have a much better tweeter, and therefore have much louder and clearer highs, but the woofer is still the same size so there is not an increase in bass, and with louder highs but not louder bass, they feel like the bass is actually less.
also you having the OEM subs mean that your really not going to be worried about actual bass, the subs handle that, your door speakers will mostly be handling mid bass mids and highs
the biggest advantage to components is that the higher mounted tweeter gives a wider sound stage and being higher makes it less likely for some of the sound to get muffled by a passengers legs. if this is not a problem for you, then you would probably be fine with a drop in coaxial speaker, not to mention its a lot easier to put in since there is not a tweeter to mount somewhere and a crossover to wire in.
Place the palms of your hands over your ears with fingers resting gently on the back of your head. Your middle fingers should point toward one another just above the base of your skull. Place your index fingers on top of you middle fingers and snap them (the index fingers) onto the skull making a loud, drumming noise. Repeat 40-50 times. Some people experience immediate relief with this method. Repeat several times a day for as long as necessary to reduce tinnitus
My only concern was if the fronts were too bassless, the bass would just sound like it was coming from the back, rather than sounding like it's part of the music. I guess some DSP tuning in my aftermarket head would fix that.
I ordered a replacement from FordParts.com - $25.86, shipped to the dealer for free. Better than Pick-N-Pull, better than EBay.
