Hello all. Been lurking here for a little while now and just recently got an 05 LS V8 with HIDs and THX/nav.
Bought it with a non-functional door speaker amp (apparently fried) but the sub and sub amp are still working fine.
Will be installing a Pioneer X910BT headunit and was wondering what would be some suggestions for the door speakers and 4-channel amp?
I plan on keeping the factory sub and sub-amp (pretty sure I can wire it up with the pin-outs that a LVC member gave me and a self-built
5V regulator circuit on the turn-on line to remove the subwoofer pop), but not doing anything crazy like QuikLS, 1LoudLS or 04SCTLS
Looking at some threads here on LVC, I've seen the Infinity References and Kappas mentioned. I think non-component speakers would be
preferable so that I don't have to go digging holes in the interior. How do these look?
http://signature.crutchfield.com/s_1086829CF/Infinity-Kappa-682-9cf.html?o=p&showAll=Y&tp=105
Also plan on using as much of the stock wiring as possible to keep things simple/neat. Would these work to hook up aftermarket speakers
to the stock wiring?
http://www.bestbuy.com/site/Metra+-...597222&skuId=3866409&st=1999 and up ford wire
Last but not least, the door speaker amp. How would the built in amp on the X910BT fare? Is it worth it to get a replacement stock THX/nav
amp (if cheap enough)? I heard that you would get inteference even when manually wiring an aftermarket HU according to the pin-outs because
the stock amp is simply incompatible with anything other than the stock THX/nav HU (but don't know whether this is true). Basically looking
for a solution that would be at least comparable to the factory THX setup.
Many, many thanks for your time and keep on rockin' LVC!
BTW : Does anyone have any old-style LVC decals to spare? My 05 LS V8 is silver and I would love having the "factory look" like this guy here :
http://www.lincolnvscadillac.com/showpost.php?p=575227&postcount=724 No offense, but the new style decals are kinda fugly.
