Spark Plug Firing Pattern, Changing plug wires
uxler
Los Angeles
Putting a set of cobra wires on my car but can seem to figure where each wire is supposed to plug into the coil pack. On the engine block side its obviously 1-4 and 5-8 front to back on eacj side but i cant make sense of the coil side of the wires. Any help?
CYLINDERS
4-......-8
3-......-7
2-......-6
1-......-5
(FRONT)
COILPACKS
13......78
65......42
Order: 1-3-7-2-6-5-4-8
unity said:
CYLINDERS
4-......-8
3-......-7
2-......-6
1-......-5
(FRONT)
COILPACKS
13......78
65......42
What year car is this for? This is different from my 94 coil packs.
My 94's are:
63.....72
15.....48
They changed them but, I'm not sure what year.
I just noted them as I took them off, and did them one by one to be sure. This may not help you now, but it's probably the easiest for the next time.
Thats news to me, but I dont think it matters. If you guys are right, and in 96 it changed, then I did my 95 as a 96 when I had it and it ran fine. Besides, the pairs are still the same so there should be no matter then anyway. Remeber, 2 spark pugs fire at once, hence 4 trigger wires for 8 plugs. Pairs are: 1&6, 3&5, 7&4, 8&2 So as long as the same piston pairs fire, no problem.
