Markviiiedrea
Speed Bump
on my Town Car I did compression check last night and after I got everything back together I took it for a test lap around the block. I knew there were only 2 threads holding the plug in on cyl 3 and when I put the plug back in it, it tightend up. But I was a little more gingerly with the tourqe because of the damaged threads.
Well a soon as I gave her 1/4 throttle it poped out so I limped it home but was unable to reinstall because of the threads. The local shop says they will look at it but dont know if they can fix it.
So.... My question is has any here done a helicoil/time sert with the head still in the car? As soon as northern opens up I'm going to check and see if they have a kit. This is my only car so a solution has to be completed soon. (the mark is buried behind a few ton's of snow.)
Thanks
Thanks
