Some tips to detour soaring gas prices
Joeychgo
Administrator
Staff member
Chicago, IL
By Gregory Karp
Of The Morning Call
Posted April 3, 2005
Here we go again. Gasoline prices are breaking through the barrier of $2 a gallon, and some dire forecasts see prices going to $3 by summer.
At current prices, a typical family would spend $3,000 a year on gasoline, assuming two vehicles that get 20 miles per gallon and drive 15,000 miles annually. A bump up to $3 a gallon would push annual spending to $4,500.
And while you can't do anything about the rise in gasoline prices, you can reduce the amount of gas you use.
True, the type of car or truck you drive is the biggest factor in how far you stretch a gallon of gas. So that won't change in the near-term, unless you are car-shopping. But there are several ways to get more miles from your gasoline dollars now.
Here are do's and don'ts for getting more value from fill-ups, adapted from tips by the Alliance to Save Energy, the Environmental Protection Agency, the Department of Energy, the Federal Trade Commission and AAA.
Do's
-- Do check for the lowest prices in your area. Online site GasBuddy.com allows you to compare gas prices in your area as reported by fellow drivers. But don't go far out of your way to save a few pennies. Any savings will be used up traveling to a distant service station.
-- Do get a tuneup. A poorly tuned engine can increase fuel consumption 4 percent, and fixing a faulty oxygen sensor could improve mileage 40 percent.
-- Do replace air and oil filters. Clogged air filters can increase fuel consumption 10 percent.
-- Do keep tires inflated. Underinflated tires can increase fuel consumption more than 3 percent. Find the proper inflation level on the driver's side door jamb or in the owner's manual.
-- Do use the right oil. Use the recommended grade of motor oil, preferably one with "energy conserving" on the label. Gas mileage could improve 1 to 2 percent.
-- Do use cruise control. Using your vehicle's overdrive gears and cruise control improves fuel economy.
-- Do combine trips. Several short trips taken from a cold start can use twice as much fuel as one trip covering the same distance when the engine is warm.
-- Do take the smaller car on errands. If you own more than one vehicle, drive the one that gets better mileage for running around town.
Don'ts
-- Don't be a lead foot. Each 5 miles per hour above 60 is like paying an additional dime per gallon.
-- Don't drive like a jack rabbit. Anticipate traffic conditions to avoid sudden braking and acceleration. Aggressive driving can lower gas mileage 33 percent on the highway and 5 percent in the city.
-- Don't bother with gas additives. Advertisements for gasoline additives that supposedly deliver better mileage are exaggerations or outright lies, according to the Environmental Protection Agency, which has tested more than 100 of them. Some additives might even harm your vehicle.
-- Don't keep junk in the trunk. Each 100 pounds reduces gas mileage by 2 percent.
-- Don't piggyback. Carrying large items on the roof of the vehicle creates drag that can cut gas mileage 5 percent.
-- Don't overbuy. Buy regular-grade gasoline, unless your owner's manual says otherwise. Costlier high-octane gas does not improve performance and could actually hurt gas mileage.
-- Don't run air conditioning unnecessarily, but don't lower your windows, either. Both create drag on the car.
More radical changes in your driving habits include changing your work hours to avoid rush-hour traffic, using carpools and ride-sharing programs, taking public transportation, walking to work and working from home.
And if you're in the market for a new vehicle, consider a high-mileage car or even a hybrid gas-electric car, which can qualify for a tax deduction.
Among 2005 car models, 11 get 40 miles per gallon or more. However, research how much you're likely to save on gas versus the higher prices of some of these cars. Fuel-efficient cars may be more environmentally friendly, which is noble, but from strictly a consumer standpoint they may also be more expensive overall.
A new online calculator is at www.40mpg.org, sponsored by the non-profit Civil Society Institute. It figures switching from a 20 m.p.g. vehicle to a 40 m.p.g. one would save $750 a year, burn 375 fewer gallons of gas and emit 7,500 fewer pounds of carbon dioxide. That assumes $2 a gallon and 15,000 miles per year.
For more fuel savings information go online to: www.ase.org www.fueleconomy.gov www.greenercars.com
Those are some good tips but I have to disagree with this one:
I have ran all three grades in my LS. The owner's manual recommends at least 91 octane in the LS and it ain't lying. I've got worse gas mileage and performance on the 87 and 89 octanes. Here in Tennessee 93 octane is readily available and it does make a difference in the higher compression running LS. It costs on average about 20 cents more a gallon for the 93 octane compared to 87. That's about $3.20 more per fill up than regular 87. Considering the better gas mileage and how it runs it is worth it.
Has anyone had any problems with hesitation when passing or entering the highway? My car seem to have about a 1 to 2 sec hesitation then it getti' up's and goes. I use on the 93 octane and get anywhere from 19 to 22 mph.
Also there is pinging I can hear when I am in the inside lane next to the median wall. Otherwise the car is great.
I couldn't agree more!
for the few dollars you pay for 93, it's worth it...
a car is like a person, the better the food, the better the person..
it's like this...
87-beer and cigarettes
89-Soda and candy
93-Wine and Steak Dinner
Personally, I know what it's like..the car starts and runs a lot easier with 93 as opposed to the 87-89.
:Beer
pesn.com/2005/03/17/6900069_Acetone
I have read up on this and it looks promising. I just bought some acetone and will be trying it in a '90 T-bird 3.8L and my '89 F250 HD 4X4 351 when I get over my broken ankle. I will see what I can find out with the bird this coming up week. It may be a while before I post any results so bear with me. Me and crutches ain't to fast. I've read to use around 2oz per ten gallons.
is that 19 -22 on the highway? it should be alot more. it sounds like you really need some filters changed, start withthe fuel and the air, cuz it sounds like a fuel delivery problem.
alrighty then i read the article on acetone ,said what the hell and have put it into my 1996 continental.in a word it seems to be working.i put 4 ounces into my tank and filled up today.then after driving my normal way to work and back my gas mileage was showing a solid 29.9mpg.my normal for this trip is 26.2.i check this mileage all the time.i also did some in town driving tonight cold engine fresh reset about 30 minutes stop and go.when i pulled into my drive the mpg readout was sitting dead on 19.7mpg.the engine is idleing so smoothly that you cant feel it by laying your hand on the car.
i am very impressed so far and plan to keep trying this out for the next several fillups and i will post the data as i get it.
ill let you guys know if my dte really does go up and stay up.
john :L
Quick question...Cadillac states that I should use premium gas only. Is this true? can I get buy with mid grade?
Maybe but its worth paying $3 more a week for a little performance and reassurance that you have better gas
yea, I aggree...
if you put midgrade in, it just won't start up as easily and won't run quite as well...just not worth the few dollars you save... :Beer
ok first update on the acetone experiment my mpg HAS been going up.the last 2 days ive been showing a mpg of 30.3 on my 20 mile one way drive to work.the car is definatly running smoother and so far im happy with the results.
john
:L
The BEST way to save on gas is this !!!!!!!!!!!!!!!!
"AND the BEST way to save on gas is too":
"ELECT a PRESIDENT that cares more about the working man then about
the big Oil company's" !!! I tryed to tell you what this one was all about. BUT NO you did not won't to listen to me. Now look what you got, And it is going to get worse before it is over.
stock prices are falling (but he still won't's to put our SS monie into it, DUMM DUMM DE DUMM). there is no monie to fix SS but there is monie to pay for a unneeded war, $87 BIL
75 BIL
and now ----- 9 BIL more
= $171 BIL
NOW I know that I am off a little bet but still that is more then enough to fix the SS problem, the interest on 171 BIL alone (by the time we would need it) would do it. And there would be enough lift over to build a Oil refin. or two.
Will anyway you know who you have to think for all of this, NO NO NO NOT the Pres. ,,It's the voters who put hem there in the first place. Because you know what he was all about, BECAUSE I TOLD YOU !!!!!!!!!!!!!! LOL
JUST HAVING A LITTLE FUN WITH THE TRUTH my friend's :dancefool
john
:L
What was the difference in mpg is there any down side that you have noticed from it?
75 BIL
= $171 BIL
Your complaints about the pres are better said in the political forum. This is not a forum for political opinions as many are turned off by them. I'd love to reply to your rantings, though, if you want to start a thread over there.
By Gregory Karp
Of The Morning Call
yeah, lets all sweat to death.... just to save a few pennies at the pump. :woowoo2:
