Bodyshield
so after daily driving my car today you notice all the little things when u drive without the radio on...so here are some things and you all might know how to resolve them, i briefly looked at some search results but found nothing pinpointed
when the car is at a stop and i release my breaks slightly, the brakes obviously rub abit, but make a rubbing noise, as if the brakes arent get brake fluid, as if its, the metal on metal touch. is everyones LS like that or should i have it looked into. i know this wouldnt be under warranty either cause they will just say its brakes, even tho the car only has 11k on it
another is the door hinges when full opened make a squeek, i've tightened the bolts down and they still do, it seems as if the metal its on is too flimsy and gives lei-way
does anyone have a problem when they shut the door (passenger front door in this case) of hearing a shaking noise that sounds as if its inside the door?
the roof interior piece moves alot when driving 60+ mph with all the windows down, is there something to create a better adhesive or should i just not worry about it?
the trunk opens on its own, but when it reachs the top the momentum of it opening literally shakes the car a bit, should i be worried about this or its not a concern?
does anyone hear any suspension compression of the springs or anything when going over speed bumps, cause i do when i dont have the stereo on, and dont know if its just the compression of the shock cause of the different suspension (v8)?
Anyone put a projective screen over the navigation to prevent scratchs? if so what do u recommend to prevent glare? and my screen gets the lines on it if the AC is on max (auto) but the lines go away when its turned down or off
thanks in advance, ill research these upon my further investigation but im at work and wanted to see if anyone had the same problem/resolutions?
05 lincoln Ultimate
11k
mark - san antonio
05 lincoln Ultimate
11k
mark - san antonio
