Gen 1, right?
Electric fan conversion.
The brown/green wires are for the hydraulic fan pump actuator. Not sure why they were cut - that connector usually comes off pretty easy. Might've started a conversion using one of my boxes (which needs those wires) but stopped. The PO just used existing taps to pull power from the distribution block instead of tapping an existing wire. Hopefully there's a fuse somewhere!
joegr said:It's better to keep all this in the open forum. Fix what? The solenoid error? The operation of the fan? Is there overheating? ...
there is a whistling sound when running the engine hard, and to fix the operation of the fan
there is no overheating drive it daily. and what should i do to fix the soleniod error as well i dont like to see all those wires in my fuse box ahhah
qty 4 typical 1k resistors in parallel across the two leads will work. That's the load segment of my circuit. Note that one of those wires is hot when ignition is on. IIRC, it's the green wire. At least tape off the ends of the wires until you get it properly fixed.
Finding a complete v8 engine in the pick'n'pull yards is still pretty tough. V6s stick around, but folks yank the v8s pretty fast.
