SLight thud in the rear end.
Dave 88 LSC
NYC
I noticed while coasting if i press the accelerator again I get a faint thud coming from the rear end. Its almost as if the Ujoints are bad but they look good and I have no vibrations.
Also, I turned rear wheel a bit when the car was on the lift and could duplicate the thud. Hard to tell if its inside the pumpkin or the drive shaft.
There was a bit of play.
Ideas?
Diff mount bushings.
http://www.supercoupeperformance.com/partBrowser.aspx?PartID=189
And this is a new epic piece...
http://www.supercoupeperformance.com/partBrowser.aspx?partId=833
Wether you want to buy from bill or not is open to debate... I think DLF makes diff bushings... I think.
I don't, I use Energy Suspension front diff mounts.
http://www.energysuspensionparts.com/proddetail.asp?prod=4.1126
And that price on the "new epic piece" is un:q:q:q:qingbelievable! You would think for that kind of $$, he'd at least include a better bolt! :eek:
All I can say about that part is about damn time someone made a beefed up rear mount... would I buy that one at that price... HELL no, but it gives me inspiration to make my own :P
