Should I change links?
tireman
atlanta
Had my rear tire off today fixing a flat and I looked at the back links, the boots are tornup. Is it worth while to change the links or should I just let it go.
01V6 115k.
The boots on the rear links of my 04 are cracked and split too (although, no wheels have fallen off).
My plan is to watch them and wait until they get really loose, or otherwise show some symptoms of problems.
I just replaced all my sway bar links and rear toe-links. The toe-links were all dried out and the non dried grease fittings were leaking, in addition to that - the rod was very rusted and pitted from corrosion.
