mistermaclincoln
Well everyone, my 95 LSC alternator burn up at the main connector on my way home from work last night. Radio/CD player and attenna started turning off and on, battery light came on and the ABS light came on. Then the message center message stated to check the starting system. Luckily I was close to home. At startup I always hear a sweaking sound coming from a pulley so I thought it was coming from a belt pulley so I took the belt off and turned them and they are fine. The altenator pulley is a little noisey when turning put turns pretty good. I check the the voltage while running and it was at 9.7 volts so I shut it down and I am checking for shorts from the altenator, fuses. Haven't found anything yet. Also, I have charged my battery and I am going to pickup a new alternator. What do y'all think!!
