Shifter cable removal
FASTLLS
Upper Peninsula, Michigan
Can someone certify how to remove the shifter cable end.. Does it have to be in the unlock position? Or do you get a screw driver behind it and pry? Because I tried putting a screw driver behind it and I put a fair amount of force on it and it didn't do anything.. I really don't want to break it.
Just pry on it between the shifter arm and the connector. It just pops off.
I put it on with my hand as far as I could then used slip joint pliers and put just enough pressure to click it in.. with the help of some WD-40 of course..
