Setting base timing
jimbob
UK
Hey guys,
My 92 MK VII BB has been running a little rough of late, with a little hesitation when accelerating from low revs under load.
I pulled the codes, nothing on the KOEO but went to check the timing at idle before i did the timing advance test and it was way off..cant remember what it was now, but no where near the 10deg BTDC that my manual specifies.
So.. am i checking the timing correctly? do i have to disconnect anything from the dist? i read something somewhere about a SPOUT connector or something?
I want to be sure im checking the timing correctly before i start adjusting anything.
Thanks
Thanks Tourqemonkey,
Didnt think if checking the tech section!! ..doh!
Thats exactly what i wanted.
