Seat Problem
Patrick00LS
Tampa
The plastic part of the back of my leather seats keep coming off. It seems as though it's only held by 2 plastic pieces on the bottom and hooks to the sides and the top. Well, the 2 plastic pieces on the bottom may be a little worn out. But it doesn't seem that this would cause the seats to not latch on properly. Has anyone else had this problem? If so, what did you do to fix it.
Also, I tried searching and couldn't find anything. Any info would be greatly apprecaited. Thanks!!!
ok, nevermind, i'm an idiot. Looked at it today, one of the side clilps are broke. I called Lincoln and they want $110 for a new one!!! DOH!
Wow! Ya sure you can't repair the clips using GOOP or other epoxy? You could save some $$.
I don't see where the broken part of the clip is at. The car came with it like that. I called all the junk yards around too. Can't find anything. As long as it's broke, it will sag too and eventually fall.
