SCT Pro Rave Live Link help...
Ya. As I learn more I want to start over. I will take it slow of course. With what I have now the car really wakes up at heavy to full throttle. Its like a beast compared to before, but I can tell the exhaust is back to being off again.
But really now all I have is a tune with the "right" injector values and some basic Mach fuel tables. I will go from here. At least I can go WOT now without backfiring or hesitation. I have a slight idle issue, but I know what I need to change for that. New TB and IAC change idle air.
did you get knock sensor into your datalog?
Frack, I forgot about those. I have to datalog and see whats up with those. Either I selected the wrong parameter or they are not installed right.
They are the Aviator sensors since the stock MK8 sensors would not thread into the block. I then wired them the same as the MK8 sensors, but without any wiring diagrams I had to guess what was ground and hot.
datalog
knock sensor retard
spark advance
spark source
add those to your log config
There is only one value I can pick for knock sensors, and they are not throwing any data it would seem.
I have another MUCH SMALLER log with my current tune.
I would attach but this fricken site has 1980s file size restrictions. Will e-mail.
