I have a INNOVA 3100, bout $100. cant do too much with it other than read and clear codes. for that it works great. or course, if I had more money, actually if it was more of a priority, I would like to have a real scan tool that can read annd display whats going on in live time and do a lot of the dealer stuff. but right now, I wouldn't use it enough to justify the price.
Sct tuner, reads and deletes codes. Got it for the tune though, being able to read the codes is just an added bonus
Custom tunes. Yeah you notice the difference, mainly in the improvement to the transmission shifts and quickness of it. I also need it to get the dyno tune for the turbo setupWhat tunes did you flash, what kind of results did you receive?
I just ordered a ELM for wifi/ios/android/windows and give it a test.
At 155mph and 13mpg.....is that your 3 mile stretch?
Just an FYI: I have two adapters.
Also, even though I selected English for the install, it loaded in Romanian. A few Google translates later, I made it through the menus and fixed it.
That's my FORscan "tune". Note the odometer
By the way, how are you separating/adding multiple quotes when you post?
Thanks for the heads up, hopefully it will pair up with no problems in English. If not I guess I will take it as another challenge.
Ok I see now what you were doing lol. I feel like a jackazz. By the way, how are you separating/adding multiple quotes when you post?[/QUOTE
and then seperate it like this
Ok I see now what you were doing lol. I feel like a jackazz. By the way, how are you separating/adding multiple quotes when you post?[/QUOTEthen copy the beginning tag over to the second chunk
Ok I see now what you were doing lol. I feel like a jackazz. By the way, how are you separating/adding multiple quotes when you post?[/QUOTEthen take the end tag and put it on the first chunk like this
Thanks for the heads up, hopefully it will pair up with no problems in English. If not I guess I will take it as another challenge. [/QUOTE
Ok I see now what you were doing lol. I feel like a jackazz. By the way, how are you separating/adding multiple quotes when you post?[/QUOTEand thats really it, here is the same thing with the correct end brackets
you can also remove all the text that doesnt apply
That's great, thanks for the info! [...] Knowledge is wisdom.
No problem, I fooled a lot of people on Facebook with it
very easy, if its from the same person, you take their qoute, and then you edit it in to separate chunks, then you copy and pase the beginning "qoute tag" and the ending "qoute tag" to make sure each chunk has it...
