SC Sway bar
whiteshark
usa
Can anyone tell me if the super coupe rear sway bar fits the 98 Mk? What is the differance in it and the stock one? I have a 1 1/4 Addco and do not like it. Will the Addco front bar come with the poly bushings, end links etc? I may just go ahead and add the 1.25 to the front and use the rear one I have now. I'm looking into going to Shelby 18 x 9 wheels for it.
Why dont you like your Addco? I have the 1.25" Addco and love it.
I don't know if the SC bar fits, but getting a matching Addco bar for the front will balance it out more...
Physically a SC bar will fit, with the correct bushings.
However, I'm quite pleased with my front and rear 1 1/4" ADDCO bars.
I agree with everyone else, you need to change the front bar also.
Yes, you can put the rear sway bar on. Just make sure you have the proper bushings.
It's not quite as thick as the Addeco bar, but thicker than the hollow MarkVIII one.
I PUT A SC BAR ON THE REAR cuase mine snapped. i used the factory bushings ,ect and it works fine.
I put a SC rear bar on my 94 when i had it, got the bar from the you pull-it, paid $5, took the bushings, brackets and end links......bolted right up, for the price, you couldn't beat it!
