John Hubertz
...I've got the dreaded rusty pan
- it is beginning to leak. Can it be repaired in-car? I'm thinking of trying the same "clay" epoxy covered with a thick coat of flex liquid epoxy that worked on a punctured pan, followed by a nice thick coat of no-rust primer and paint.....
I remember on the punctured pan the hardest part was using a propane torch for about an hour to thoroughly leach the oil from the surrounding metal.... I heated it and heated it..... with an empty pan....this time I'm thinking I'll use a quart of motor-flush first to make sure the pan is as clean as possible before I heat it. I'll be a little more nervous with the small INSIDE the pan fire this time I'm sure......but WTF.
Any suggestions or recommended techniques? No way I'm pulling the pan without trying to repair it.
