gopaperless
I have a 2002 LS V8. If I make a left turn and accelerate, there is a sound like something rubbing against the treads of the tire (the front right side). Doesn't do it if I coast through the turn. I checked the wheel well and there is nothing that could be rubbing. I can push the top if the tire and feel and hear a little movement. I immediately thought wheel bearing although there isn't any noise while going straight. Went to get the part and the parts guy said that it could be a ball joint because wheel bearings make noise when you go straight. I inspected the lower ball joint on that wheel and the boot looks great. Any thoughts? Could I have a bad wheel bearing that only makes noise when I turn?
