Rubber isolator cap around spark plug
soduka
SD
Went to change my spark plugs. 6 of them came out fine, two of the boots pulled out but left the rubber cap snug around the spark plug down there, meaning I can't get a socket around it to take it out. If anyone else has faced this before, what do I do? Really really long, really thin needle nose pliers?
Yep those would pull them out.
You can also find a thin rod, make one end pointy and just tear away at it until it falls apart. Blow the pieces out of the hole with air (while the plug is still in, of course). I did that with SIX of them when the previous owner used cheap wires. The wires were BRAND NEW.
