Rough idle on hot restart
Garbone
Kirkland
Anybody have their LS run rough when you run it for awhile, shut it off for 10 minutes, then re-start...like running into a convenience store?
I need to find out whats up. it doesnt happen all of the time, and clears itself if I shut it off, then start it right back up.
I am going to try and clean the MAFS...with the proper cleaner...and see if that helps.
Any ideas out there?
Hey, I have a question.. Just bought a 2002 LSE V8. And it rides rough! Is that how these cars ride or is something wrong? It has that sporty Z28 ride to it
Garbone - thats one symptom of leaky fuel injectors
Geedy - More than likely your COPs and VCG gasket combination. Use search function
I have a coil or two going bad, and mine does this.
From a cold start the engine is fine.
But if I run then shut off, then restart like <60 min from turning it off, the car runs rough.
It has been doing this for about a week now. I am going to do the coils this weekend.
I'm with Eric on this. I would first suspect leaky fuel injector(s).
Thanks, great suggestion...
I gave it all new coils, and plugs less than a year ago.
vacuum leak
check for vacuum leaks, your rubber hoses may have cracked
