Terminator
Hello,
Of course I searched for this prior to posting but no threads addressed my exact issue. I had recently replaced all coil packs, all spark plugs, new air air filter, fresh oil change. New EGR, and unrelated, a new radiator but my question is, my 2006 LS has a rough idle when fully warmed up, and the A/C off. In other words at lowest idle. When the A/C is turned on, as you know the idle automatically ticks up, smooth idle. And when the car is warming up the idle is up a bit, so its smooth. Acceleration is smooth, no codes. Only at full warm up when A/C is OFF, the car has a pretty bad idle. Before I did all the above work, the car idled smoothly at all times. I cleaned MAF, un plugged the TPS, and IAC. Cleaned the TB, to no avail. I read somewhere a bad fuel pressure sensor could cause a lean idle condition thus a bad idle, but I would think that would throw a code. I dont know. Any help would be greatly appreciate.
