Roof drain terminus????
rgorke
Camarillo, CA
where does the sun/moon roof drain line end? IOW, where does the water come out? Mine is clogged and I am trying to see what might be blocking it on the bottom end.
I have fixed the top portion but it backs up in the tube and doesn’t drain.
Which one? There are four of them.
The two in the trunk are easy. The two up front are a little harder to get to.
Actually, the front drivers side.
I did find it or I should say I “saw” it. It turns out I created my own crisis. I fixed the connection point with a male/male nipple and small piece of hose. When I tested it for leaks, I poured too much water in the tray and it overflowed. I thought the hose was clogged not realizing that I exceeded the designed capacity of the drain.
What a dope!!! All good now!!
