nearlyhalfamile
I've had a 2001 LS V8 for about a week now and I have this problem with the right front parking light, turn signal, bumper marker light, and fog light. None of the mention lights work, but only on the right side. The information center in the dash says to check the right turn signal lamps. All the bulbs check out ok, as well as the #8 fuse in the fuse block on the passenger kick panel. I also checked a couple things with my multimeter and the ground on the connectors for the lights is grounded, but with the lights on they do not get power and power (+12v) does go through the fuse block and into the apporiate wire (orange/blue I think) coming out of a connector on the fuse block also has power. Any ideas what this can be? Everything on the left side works perfectly and the right rear parking light and turn signal work fine and the right head light high/low work fine too. I'm guessing it may be a relay controls power going to the right front lighting assembly, however I don't know where this might be. Would anyone happen to know this or what else may be causing the problem?
