Riding with bad bearing??
blackheart102001
Tampa
Whats the ultimate consequence? I got a little vibrating but I can live with it. Dont have a lot of money right now how long can i go with out getting it fixed. Is it safe to drive?
If you can come up with around 65 bux (for the front hub assembly, assuming this is the bad bearing) you can get the Duralast brand from autozone.
hey im driving with a bad ac compressor clutch, i spray it down with wd40 then it sounds like a supercharger, real fierce haha:D
worst case....I guess it will lock up, and cause you to get a tow...and maybe.....the wheel could fall off...breaking your rotor and f'ing up the caliper along the way.
I drove mine till it was vibrating real bad. the front never really got worse, and I changed it. the rear wheel was so loose, it leaned and started to chew up my rotor.
