Required parts for Cobra intake swap?
Thanks for that link.... but I did that long before deciding to do the swap, your thread on LOD was better. ;)
The nature of my post was specifically that ad, as it doesn't list any part names or numbers: It just says "All parts pictured", and I'm not savvy enough yet to identify what parts might be missing. Things like IMRC bits and all the little valves and junk that tends to get bolted to intake manifolds and throttle bodies. I think I see and EGR, but what about IACs and things related to throttle cables etc etc.
Thanks again
get a cobra throttle cable and intake tube, I used a rubber sewer coupling to hook up the intake tube to the air box. also you will need to extend some wiring harnesses and vacuum hoses so plan accordingly
Well, that ad has expired, but it didn't include the EGR valve or throttle cable bracket, and if you're going to retain the IMRC's, you can use the set that's already on your car.
