Adam Moore
Hey guys whats the best way to replace the transmission fluid. I have the V6 not sure if its different than the v8. Thanks
Personally, that just sounds like a pan drain/filter change and refill.. And that's expensive for just that..
Dealer will flush for under 200
There really is little difference between Mercron V and III.And, the dealer will put the correct Mercon V fluid back in, not some universal crap.
Like I said, taking it in will get 99% of the fluid out.. So IMO, that is the better way
Has anyone had their transmission flush done at the ford or lincoln dealer? if so how much does it cost on average?
I think you need to read good sir..I think I was quoted 196 exactly
325$ transmission flush and Rear differential flush
Why don't you like the flush? It gets 99% of the old fluid out.. Dropping the pan gets maybe 30%..
