Very nice mtggtmmtg! What all did you do to mount the LED brake light? Will I need to drive screws through my headliner? Is that an OEM unit?
Yes, it is an oem unit from an 03 LS. I've added pics of the LED brake lamp & capicitor, as you can see the unit has 2 clips in the center that will hold the unit in place & instead of the 2 mounting bolts I used double sided tape so I did'nt have to remove the headliner. I will also add pics of other LED lamps that I had in case you want a different look.
Also, very nice with the OEM nav in a first gen. You are the first person that I have seen that has successfully done this.
Thanks, most people go with aftermarket, but I really like the THX sound. Unfortunately I still have the 03 nav DVD that has limited coverage for my area. The LS is not very popular in my area so I have'nt been able to find anyone with the newest DVD map version to try out or make a copy of and since they(Navteq) wants $199 for the update I may just buy a Garmin for $99 so I can use it in my other vehicles.
