kingofmy_h
I need a new compressor, condenser, drier and expansion valve. Should I buy used from ebay or new from aftermarket sites? How much should i expect to pay for labor? Thanks.
...How much should i expect to pay for labor? Thanks.
A whole lot. The dash has to come apart to change out the expansion valve.
Ah hell!! No wonder Firestone quoted me nearly $700 to remove and replace the expansion valve... I've had my ls since 05 but I think it's time to move on.
How does Firestone know the evaporator is bad or are they guessing and throwing parts at it? I would take it to Ford and pay the $100 and have it diagnosed properly.
I decided that I will do the job myself. I am only replacing the compressor, drier and condenser. Is this what I have to do:
1. Take it to the shop so they can recover the refrigerant
2. Replace the parts
3. Once all parts are back on, take it to have it flushed
4. Add refrigerant.
It looks like a easy job but is it? Any advice/tips?
...You're a better man than me if you take R143a to be recovered.
I'm changing the compressor on my LS, and I ran into one problem, getting the top right bolt off. I have two questions what size is the bolt after you take off the line and is there a special way to get to the it. thanks for your help.
