1MiC
Hey guys, so i've been having rough idle/misfires, also CEL which i knew was my coils. I replaced all 8 coils on wed (2/20). No oil leaking in, and spark plugs (which were replaced 10k miles ago, i'm at 103k currently) still looked good and were set to 1mm gap.
Now I've read about driving with bad coils however i was waiting for my income tax for the money, so i may have put about 500-750 miles on my car since i started getting a CEL. I went to check the codes today and i got P0353, which i read was a bad coil, and p0133 on bank 1, which i read was the drivers side 02 sensor. That code he said popped up twice, i guess that means both sensors? He told me if i disconnect my battery the coil code will probably go away, and i guess ill buy some 02 sensors to replace driver side.
My real problem however is a very rough idle while in gear, specifically reverse. I can feel it in P and D, but not as bad as when i put it in reverse. It also increased a significant amount after i had the COPS changed. Any idea what might be causing it? I asked my mechanic about possible a vacuum leak but he said i'd be able to hear it. The only thing i can hear is a whistle from the intake while it's in reverse, it kind of sputters and makes a whistle sound every couple of seconds.
Hopefully i gave enough info, Any advice would be greatly appreciated!
