Well, after thinking about it, I started to wonder why I was putting a new coil over on the 'older' car (the project Mark).
The suspension on the LSC works fine, if a little soft atm, so I've decided to replace the LSC with new and shift the old parts over to the project car.
I have one "good" rear bag off the project car. They fit either side, and your welcome to if you want it.
As I said, all the stuff looks pretty old, however it was still holding air when I took it off, so it's probably better then one that is leaking.
You were also interested in the shocks, and you can have those also. However, they 'seem' pretty shot, I can push the one in by hand with almost no effort (the other is slightly stiffer). I don't think you would be happy with them, but if you want they are here.
I'm raising cash for replacing the rear bags and shocks on the LSC atm (and things always seem to come first, unfortunately). Once that's done, I'm moving up to the front end.
Now, the other thing is that the engine in the project car 'appears' to run well, but I'm not 100% sure about the transmission. If it is shot, I will be able to make you a deal on a casing at least.
As for the engine rebuild, I'm free every weekend.
