TheRebel
I have a galaxy 2000RS remote start and a Directed Electronics 1100F security bypass module (no key required). I cannot get my 03 LS V8 to start without the key in the ignition. If I leave the key in, the car starts but the check advance trac and service parking brake messages pop up. I can press reset on the dash controls and the two messages will go away (parking brake works fine). I tried to see if there were any DTCs with my Xcal but none were listed. If I start the car with the factory key I get no messages and everything is working fine. The module has a wire that is suppose to be connected to a “ground only when running”. I cannot find one. The remote start also has the same type of ground wire. I called directed electronics (no help) and they said the ground only when running wire on the module should be connected to the ground only when running wire on the remote start. Did that and still can’t get the car to start without the key in the ignition and I still got the error messages. Anyone got any ideas?
