Remote locks/unlocks the pass. door but not drivers??
vikingdiesel
Chicago
My keyless remote works and will lock and unlock but only the pass. door and sometimes the drivers door, you can here it work from the drivers side but the door pin doesnt move. Whats most likely my problem?
Worn actuator. You can remove the inner door pannel and spray some PB Blast or WD40 on th linkage and actuator and it may help for a while but eventually you will need a new one. They are all over ebay for $20-$30 shipped.
what switch, the door lock button, it seems like its not catching, im gonna hafta remove the door panel off. Any DIY writeups on door panel and actuator replacement?
pull the little trim piece behind the mirror (mine breaks every time, just glue it back together) pull the oval light in the lower corner of the door and remove the screw behind it, theres a small cover below the arm wrest theres a screw there, remove the trim around the door handle it prys off, then lift the panel straight up and off. the actuator will be below the latch and is pop riveted to the door.
