Rear toe specs
pragmatic
Tuxedo, NY
Is +0.13 +/-0.13 correct (so from 0 to 0.26 inches) positive toe each side correct?
2000 LS Sports suspension MT5
Thanks
I have it as 0.12° ± 0.25° for both sides for both generations (and same for sport or normal, V6 or V8). I'm not sure how that would convert to inches. Inches at what point?
Maybe he just has the units wrong.
No these were from Autozone web site (the only one I could find with dimensions)
http://www.autozone.com/repairguide...Alignment-Specifications/_/P-0996b43f802e8a34
Joegr's .12+/- .25 degrees that's from +.37 degrees to -.13 degrees or
in inches 0.036 +/- 0.074 that's +0.109in to - 0.038in
compared to Autozones +0.26in to 0.0in ( in degrees +0.87 to 0.0)
The +0.26in seemed too large, I was going to set it at +0.125in (0.42 degrees), based on Joegr's post I'll use +0.0625 (0.21 degrees).
Measurement is from edge of stock wheel.
Thanks
