Rear sub question
special02LS
jackson
I'm sure it's here somewhere but Im just ask the question anyway...installed an aftermarket alpine unit tonight and everything works except for rear deck subs, what's up? I knew there would be a few left over wires from harness to radio harness but need to know what wires to hook up to get amp and rear 6x9 low freq speakers working, thanks for the help guys
This sounds like what I had going on in my LS after the previous owner had an alpine installed. You will need to get the extra little harness the the two rca outputs. I got mine from Schosche or a similar company, I think you can order it off of best buy's website too. It's only like $10. The only issue I have now is the subs "pop" when the radio powers up.
http://www.scosche.com/car-audio/product/1402
yes a factory sub harness will make it work
also a 1450 ohm resistor inline with the remote turn on wire will eliminate the pop
Thanks guys that helps a ton, I consider myself savvy when it's comes to working on cars but I was bout to pull my hair out! Bald isn't s good look for me haha thanks again
