So I ordered new drilled and slotted rotors all the way around, and today after work I spent a good 4 hours or so working on getting them on. This is my first encounter with 4 wheel disc brakes, so rears were a little different for me. I rented a caliper piston tool and got the drivers side done after some problems lining up the caliper and bracket after the new pads were installed (does anyone else have problems putting the rear pads in? they didn't want to stay in one spot for me) Also, I discovered my first stuck caliper pin. no amount of PB blaster would coax this M-effer out, so i need to replace that asap, which also means i will be replacing the bracket. Cheap, so not too mad about that. but when I go to do the other rear wheel, the first bolt i encounter has a head like a hula hoop. nothing I could do to get it off right now, so I had to leave the dirty ol rotor and pads AS IS. Will this mess my new rotors and pads up if i have to drive it for maybe 10-20 miles tomorrow? Im going to probably end up getting a new bracket for that side too, along with new slide pins. The front brakes took me maybe 40 mins for both sides. at least something went right in this job. Sorry for the lengthy post, but I need to know if I'm going to ruin my new setup because i spent TOO much money to do it again.
