cammerfe
I've got a 'bootie shake' sort of motion to the rear of my '02. Since there is no noise associated, such as might indicate a loose rear cradle, I'm guessing that the radius rods with their compliant 'give' sections have finally 'gone south'. I have 152 K miles on the car.
As I noted in another thread recently, tubing with swedged threaded ends is readily available from circle track suppliers in half-inch increments and in various sizes. Creating replacements only requires dimensions from the factory parts. Threaded rod screwed into one end of the tube and a tie-rod-end or Heim joint screwed into the other and bob's-your-uncle.
The difficulty is that the car is required, due to family schedules, to be used on a daily basis. Therefore it's not possible to remove a rod to get the dimensions necessary.
Can someone supply OAL and threaded diameters for me? I'll do a write-up including sources when I get to that point.
Thanks!
KS
Thanks!
KS
