joegr
I am in the middle of replacing rear disc pads on 2K5 LS for the first time (diy). I purchased caliper tool from FH. I can turn the caliper piston (cw), but it doesn't retract. I still have about 1/4 in. of metal above the rubber boot. What am I doing wrong? Any/all suggestions are welcomed. Thanks in advance
Are you using the tool correctly? When correctly installed, the tool will exert pressure on the piston while it is turning. The piston won't go in without that pressure being applied. There's a plate that you put on the tool that presses against the part of the caliper that holds the outer brake pad.
If you have the tool setup correctly, there is no way that you can keep turning it without the piston going in or something breaking.
