So randomly my ETC failsafe will come on. Still runs good. Only thing I notice is maybe a little less power, and overdrive doesn’t work.
Park car, kill engine, restart, runs like a champ.
my traction control light and ABS light came on at the same time. They won’t go away, but the fail safe comes and goes.
codes I have -
P2106 - throttle actuator control system forced limited power
P0193 - fuel rail pressure sensor cot high input
I will also add the previous owner changed the fuel pump, and the sock fell off. Also is leaking a little fuel out of the plastic ring, so I think I’m going to get a new one with gasket. Also, fuel gauge does not work correctly.
Don’t know if this is related or not, just throwing it out there.
I have read that a bad COP on #3 or #4 cylinder can cause this.
thoughts?
codes I have -
thoughts?
