poniesviii
Frogman said:I hear those NASCAR stickers are good for 100HP a side.
:lol:
:lol: :shifty:
:lol:
MediumD said:If a car A is quicker to 60 but car B runs the 1/4 in less time and traps higher... which one is quicker Paul?
Dr. Paul said:In general, if a car is quicker to 60, it will be quicker through 1320 feet.
If a car traps higher than another, it is faster, not quicker.
MediumD said:Calabrio you won't even acknowledge that a Mark VIII can run 14s stock... I can't argue with someone who won't acknowledge something that's been proven over and over again.]/quote]
Does your run stock 14s? Do most? And are most of those cars that did it in 1993 still doing it 14 years later?
Are there some that may? It's possible. I've seen claims. Do most. No. So, when we look at these cars, do we look at the few cars at the small end of a bell curve, or do we use the majority of them in the middle for our baseline?
To compare the best case example of one to the median one of another is unfair. But with that said, even if we determine that every stock Mark VIII ran 14.9s- it doesn't change anything. That ties it with the Motor Trend numbers of the Civic Si, it's still .6 slower than the speed3, and using that figure it just barely makes it faster than a Toyota Camry.
So, I fail to see why you are making this an issue.
The only one of the cars you listed that's definitely appreciably faster than the VIII is the Mazdaspeed 3.
The 2.0 liter four cylinder is not "appreciably faster in a straight line. This is your big point? So, it's just " a little faster" in a straight line, and then corners, stops, and has better build quality.The Civic SI is NOT,
Even pretending most Mark VIIIs run a 14.9, which they don't.the Camry is NOT. Unless you think Mark VIIIs are incapable of anything better than low-mid 15s, it all goes back to you underestimating the Mark VIII.
Even according to lore, only the 93-96s had the chance of doing that. The 97-98s never broke into the 14s stock. So, if you want to compare the small part of the bell curve again, fine. End result, again, is about the same performance to the 1/4 mile, and the other figures still give the 6 cylinder Camry the advantage.
So, after all your huffing and puffing, you're basically just finding more ways to state that "those cars aren't much faster."
Yes.As far as cars in/near it's class, yep they're generally faster now as well they should be.
You're very wordy, but you're just agreeing with everything I said.As for the sport compact crowd, a few of them are faster, some of them are similar, some of them are slower - they're supposed to be sporty anyway so they should ALL be faster. The family cars and econoboxes are still, with very few exceptions, slower than the Mark VIII.
Many of the good sport compacts are now faster than the Mark VIII.
And there are still cars slower than it.
What are you taking issue with? In 1993, there really wasn't much on the road, stock, that could take the Mark VIII. Nowadays, the industry and technology have advanced and even some of the little cars will outrun it.
You're projecting alot more on my statement than I ever did. I don't care how it makes the power. Turbo, supercharger, or VTEC- it doesn't need to be explained. The point is, it's a compact, hatchback, that makes about 260 horsepower and blazes through the performance benchmarks. Turbo or not.Here's the thing about the Mazdaspeed 3. You were trying to make it look like "gee look, this mazda makes almost as much power as a Mark VIII out of a engine half the size." You neglected to mention it had a turbo. You were trying to make it out to be way more impressive than it was.
This might be relevant if we were comparing cars that were competitive. No one in their right mind thinks the 8 will handle better than any of the other cars mentioned.I'm only talking about straight line racing. Handling is nice, but it's pretty much impossible to compare car handling to other car people. You can't say "I did the standard autocross course in 39 seconds" or whatever, because there IS no standard course, whereas you can easily say "I run the 1/4 in 13.4."
And there are issues like grip, figure 8 times, and the such can be used in a pinch.
They race stoplight because it's easier.People race stoplight to stoplight WAY more than they race around curves, it's safer, there's less room for excuses, and there are way more straight roads here than curvy ones. So I personally think handling is nice but not as important than straight line acceleration. If you want handling none of these cars handle really well anyway.
Handling is what driving is about.
And if you want handling, both the speed3 and the Si are excellent.
this isn't about you.I could also give less of a crap about MPG,
You mean compared the the $40k cost of the new Mark VIII?Of course driller isn't in the 12s, he's going the N/A route which is much, much harder. I don't know how many 150 shots a 145k Mark will take either, but heck if you're comparing it to a $21k Civic SI you can either find a VERY low mileage Mark or rebuild the entire drivetrain twice over.
I've owned my Mark VIII longer than you, I've driven it more than you probably have, and I've done a considerable amount of work on it, so I'm intimately familiar with it.So you rail on about the Mark VIII being a slow POS that handles like a pig runs 15s and you say that? You're SO full of it.
Your reading comprehension is terrible. You also lack the ability to discuss something without intensely personalizing.
I've have stated, repeatedly, the Mark VIII is STILL a car that has respectable performance. This is a testament to how impressive it was when it came out, that despite time, it still is competitive.
But, it does handle like a bit of a pig, despite the bigger tires and sway bars on mine.
Who said that? Did you read, or just defensively and ignorantly respond in fits of passion?I'm not defending the Mark VIII as gods gift to performance, like I said I'm just saying not every pos an asian car maker puts out on the market is going to beat it.
The point is, many of the small imports are faster now. That wasn't the case 14 years ago.
You're the wordy guy who has, despite your intention, reinforced my arguments. Frankly, you're not even arguing at this point, you're just defensive.It's funny how you exaggerate a situation to the point of making an ass of yourself.
Calabrio said:Are there some that may? It's possible. I've seen claims. Do most. No. So, when we look at these cars, do we look at the few cars at the small end of a bell curve, or do we use the majority of them in the middle for our baseline?
Calabrio said:So, after all your huffing and puffing, you're basically just finding more ways to state that "those cars aren't much faster."
Calabrio said:I've have stated, repeatedly, the Mark VIII is STILL a car that has respectable performance. This is a testament to how impressive it was when it came out, that despite time, it still is competitive.
vr4 said:stock for stock marks are for the most part quicker than an LS. i smoked a couple over here pretty good. the new LS is quite a bit more impressive than the early 1s though.
Is Union Grove Open? Let's go and settle it.02LSE96LSC91SE84TC said:Gen2 MarkVIII vs. Gen1 LS even match up. Best will run 15.0-15.2 and 15.39 at the worse. Again bad drivers side.
My 02 will run below 15.0 stock IMO, I'm not removing the exhaust and intake to find out unless someone bets me.
Haha. I wish they were its been so nice I've called to see. The recording says if the weather allows they'll open, I guess 40s in the end of December isn't good enough.MonsterMark said:Is Union Grove Open? Let's go and settle it.![]()
02LSE96LSC91SE84TC said:Hey I got my stack of timeslips and best on video......You?
