R U F*n sure!?
RGL
Appleton
tranny,
someone said the bolt @ the bottom of the pan is not the drain bolt. then why did I get 2 Qts of fluid ot of it? Did theY over fill the tranny fluid? I am getting really POed cause I cant afford to take my car in and pay 1200 $ to have my Solinoid replaced if that isnt whats wrong! where is the solinoid located anyway?
RGL said:
tranny,
GET A MANUAL
This really is the only way to go, for a DIY project. Here is one exploded veiw of the 5R55N tranny, in two parts due to size.
The draining and filling depends on the tranny, I was going to post those, but figured I will wait to see if you reply., and post the right procedures.
You can only drain about 1/3 of the tranny fluid using traditional ways. If you would like to completely change the fluid you have to flush the system at a local shop. They pressurize your tranny forcing all the oil out. The only drawback to this procedure is that it can be dangerous with higher mileage vehicles and can weaken/burst seals.
I usually just drain and fill (traditional way) every other oil change or so just to keep it fresh. Its inexpensive, especiallly when i'm paying $6 a quart for Mobil 1 Synthetic.
Mac98SHO said:
GET A MANUAL
I would, but there's no PCM code for a manual. And then I'd have to fab up a clutch pedal assembly, and...
Oh, you mean a Service Manual, like the book? ;)
Either pop for the shop manual (an excellent idea), or drop $25 for a year-long subscription to AllData DIY. They're really cheap insurance, and they'll tell you the correct way to do things.
Always one in the crowd... I meant a SHOP MANUAL :p
2001 V 8
where is the solenoid? inside or outside of tranny? is it a drain plug? it looks like a bolt but has an allenhead scrw in the middle. and where do you fill it?
solenoid involves removing the tran pan and then it's in there. usually when they do the solenoid they do the valve body is well. those two parts are pretty pricey.
you fill it by removing the screw in the middle of the plug and then using a suction gun to SHOOT new fluid up in there. pretty messy and best left to the dealer IMO
No offense intended, but if you don't know where the solenoid is, you probably shouldn't try to do anything with it. It's part of the internals of the transmission.
You definitely need a shop manual or access to AllData. The bolt you're describing is officially called a transmission fluid fill plug. In the instructions for changing the fluid, however, the inner bolt is the fill plug, but the outer bolt is referenced as the drain plug.
Look at the exploded view that I posted/loaded for you see above.
Excuse me But!
I have never seen wires that are able to set in tranny fluid before. did tou look at all the questions I asked? Over filled? took the pan off and it does seem you fill the trans from the top untill it comes out of the bottm where nothing can come out untill its filled to the top of the little cylinder 2 inches mabe?
Im SORRY
forgot i had another thread with questions on it but still need answers got the the pan off the trans and still going
no it's all filled from the bottom. what are you doing? take that car to the dealer.
