r&r oil pan
nasu
Harman
Hi, does anyone know how tough it is to R&R the oil pan on a 1st gen v8?
If you are referring to the small metal pan that has the drain plug... what 55 said above.
The only thing I will add is... don't buy a cork gasket because it will leak. The good ones (like Mahle) are metal reinforced rubber.
And again like 55 said torque sequence is important. So is the torque (numerical)value... so you will need to borrow/buy/rent a inch pound torque wrench... and use the right sized socket.
there’s always one bolt that keeps on turning, do not force it you will break it before your torque wrench clicks
