Quick rim size help!!
Lincoln Luebbe
Lincoln Lane
I know you need at least a 42 MM offset for a 20 X 8.5 rim on a 245/35/20 tire not to rub when lowered. But would a 38 MM offset on a 19 X 8.5 rub? 245/40/19 tire size.
determines if you've lowered your ls at all and by what amount. such as I used eibach spring so I should be golden but spring springs might be seeing a different catagory :P
I have springtech springs (lower the vehicle quite a bit, actually), 19" wheels (sorry, can't remember if they are 8 or 9" wide) with 245/40/19 tires. Minimal rubbing, the the clearance is REALLY close on the back. 42 offset.
Eibachs-
4 MM is so minute I would think it might work. I'm torn over about 4 sets of wheels. I like 19's on the LS but I am the kind of guy who wants it to be right the first time. I just didn't know if losing an inch meant the other 4 MM wouldn't affect it.
I think you are going to see a bigger difference by just choosing a different tire. Go with a little narrower tire with the 38 offset, and you should be fine.
235's should do it.
I'd much prefer 18s and keep it on the performance side :-D hell 18x8 would be a nice size (when I get around to making my forged rims)
Sweet I'll keep all this in mind. It's just my daily driver but I'm hoping to get rims before summer is over.
Staff online
