Does anyone know of someone or did someone do a 5 or 6 speed swap in their mark viii. I have a 93 Mark 8 and I wanted to see if it was possible to do that and if anyone did it how hard it is and what parts would be needed. Thanks
i think about 3 or 4 of us on here have done the swap here is a PM i sent to a mamber who had the same question.
Main Parts
1.T56 from 03 cobra
2.spec stage 1 clutch
3.Stock Mustang GT flywheel (dont get a cobra they are 8 Bolts the gt is a 6 bolt like marks)
4. Mustang clutch pedal cut off and welded to mark 8 brake assembly (pic's in here http://www.lincolnvscadillac.com/showthread.php?t=43701)
5.Fab your own shifter like blender head did in this thread mine is the same but i have no pics. http://www.lincolnvscadillac.com/showthread.php?t=42658
6. also yo have to move your computer because it is right wear the clutch needs to go. for this you have a couple options you can do what i did and just cut out the heat and AC tube and duct tap the Comp up there you can still put the cover back on and it will look fine but you have no air form the 2 air duct you cut off. the plus of this is it takes no extentions of the wires and took me about 20 mins but it is not as clean of an install as blenderhead who rewired it all under the dash but that takes longer it really your call both menthods work fine.
you could also go with a hydrolic clutch but i have never installed one of those so you would have to ask blender about that.
7 u will need a custom driveshaft i recoment dennysdriveshaft.com they are a little pricy but have great service and made me a perfect driveshaft.
Some other usful links for your swap that i used this might take a couple hours to read all of it but it will really help when you start.
http://www.lincolnvscadillac.com/showthread.php?t=24218
you might want to consider a termec 6060 if you have the cash no shifter probelm and strong but a little pricyer and i think you have to go with a hydrolic clutch with this trans.
