I need to replace the turn signal switch on my '96 Town Car and have hit a problem. I got through the air bag ok, removed the retaining bolt and installed the wheel puller. The bolt holes that are for the puller to screw into were really shallow and the threads pulled right our of them. Is there any reason I can't drill all the way through the aluminum hub and retap for a better pull or is there something that I would hit if I drilled all the way through the hub? I am assuming that there is some kind of special puller to use on the original holes because there was no way that was going to work. The original holes were only about a quarter inch deep with threads only about quarter inch also. There is a small hole that goes all the way through but didn't seem to be part of any kind of puller fitting that I've ever seen. Any help would sure be appreciated here. Thanks in advance.
:feedback
:feedback
