problem with moms mark
1bad4.6l
wyandotte
when the headlights come on its just the running lights no headlights all the others work gauges tail and markers. even if you turn on the brigts now if you pull back on the bright switch and hold it there they come on. but in auto mode and manually turning the switch to on they wont work does this sound like a headlight switch issue.she says its hard to drive while you hold it back, so i guess its time i try to fix it and note the fuses are all good :confused: :confused: :confused:
Dude... seriously. Sentence strutcture. Try to break your rant up a little.
Makes it easier for people with ADD (like me, sometimes) to read, and to try and help you.
Now then. Sounds like the multifunction switch and/or wiring is out. That's the "bright switch", for you folk in MI. :D
sorry about the sentences. im adhd. thats why everything has to be done run altoger. So back to it its the switch in the column
Sounds like the switch... but the power also runs through the multi function switch... junk design imo...
The headlight sw on the dash is discontinued but I found some and retails 77.36, LVC is 67.38, the multifunction sw is 97.96 and cost you 57.30.
plus shipping.
Thank You
Max Zuckerberg
Parts Specialist
Five Star Ford
7100 east Mc Dowell Road
Scottsdale AZ 85257
Direct 1-800-866-1520 ext 236
Fax 1-480-949-8478
parts@fivestarford.com
